Clear bands/frequency
PA0MBD
Post by PA0MBD »
I frequently log a QSO from cluster or WSJT. The band and frequency fields in the logrecord are than filled. The "normal" qso's are logged most of the time without a CAT-connection. In those cases the band and frequency are not overwritten. Forgetting to clear thse fields manually causes wrong data. Unfortunately the Clear-button also does not clear these fields.
Is it possible that the Clear-button also deletes the band and frequency fields?
Tnx in advance and good luck!
73 de Martin/PA0MBD
