Would it be possible to have an option to auto download LOTW confirmations when Log4OM2 is started, Also have an option to choose which Search Confirmation is default. I primarily use electronic logs unless a paper QSL if requested.
Magnificent logging program.
Warren
KC0GU
Make Confirmation selection persistant (Sticky)
Re: Auto Download LOTW Confirmations at startup
Warren,KC0GU wrote: ↑29 Jul 2021, 17:05 Would it be possible to have an option to auto download LOTW confirmations when Log4OM2 is started, Also have an option to choose which Search Confirmation is default. I primarily use electronic logs unless a paper QSL if requested.
Warren
KC0GU
Have you looked at: Settings / Configuration / User Configuration / Confirmations ? Is this what you are referring to with respect to "Search Confirmation" ?
Auto Download (IE: LOTW) would tend to slow down the startup of L4OM, but will ask Lele about possibility.
Those are the default settings for confirmations when manually downloaded for LOTW.
Warren
Warren
Warren,
OK ... I'll admit as you have me confused.
Currently we do not have an "auto-download" for LOTW or eQSL so it stands to reason that the settings I noted in "Confirmations" are for the Q's that get 'manually' downloaded and parsed for the Awards.
I need for you to better explain your request for 'search confirmation' and possibly some screen clips of where you are looking in the configuration for such.
As I noted above I've put your LOTW "auto-download" request on Lele's list to comment once he returns from holiday.
Nolan,
Thanks for looking into this. Sorry I missed your response.
Open Utilities>QSL Manager looks like this:
Would prefer to have this:
I never use QSL as a search option.
Warren KC0GU
Warren KC0GU
- Would prefer this.jpg (29.43 KiB) Viewed 1738 times
Warren,
That request to make LOTW "sticky" has been on the possibility list for some time.
Title of thread bears no resemblance to the actual feature request required so I will edit it
