CW Keyer using CAT Interface
PE1PUX
Post by PE1PUX »
I found this YouTube tutorial on setting up N1MM Logger to transmit CW using CAT and a QCX-Mini:
https://youtu.be/P3hhDOMSR8Q
Currently I can only select WinKeyer or TCP/IP as CW Keyer Engine. It would be nice when CAT was added as an option in Log4OM. This would enable usage of Log4OM as a Keyer with radios like the QCX-Mini.
73's,
Erik, PE1PUX
Re: CW Keyer using CAT Interface
Already been requested and added to the to do list - Search this forum for details
