Is WAS fully supported?
Moderator: OE6CLD
va3vf
Post by va3vf »
If yes, is there any configuration required? I don't see anything.
Thanks,
Vince, VA3VF
Re: Is WAS fully supported?
Have you checked in awards statistics?
va3vf
Post by va3vf »
Yes, it's empty, like I have never confirmed a single State.
The other two awards I follow are DXCC and WAZ, and those work perfectly.
Thanks and 73.
Vince, VA3VF
Well as you can see it works for me so either your logbook does not have the states recorded or you need to rescan the award references in the 'Maintenance' tab of the award
va3vf
Post by va3vf »
I did a re-scan many times before, but I see now that I may not have waited long enough for it to complete.
It now shows 4 States confirmed on most bands, and 12 on one band, for a total of 25.
I actually have 248, as per ARRL LoTW.
Not a big problem, it can stay this way.
Thanks and 73.
Vince, VA3VF
You can't have 248 states, DXCC entities (countries) maybe but not states
va3vf
Post by va3vf »
Yes, I can, 5BWAS. Need VT on 15 and 10m.
73 de Vince, VA3VF
If it's the 5 band award then that is different to the standard WAS so you will need to modify the WAS award or ask Claus our award manager to do it for you
However it also sounds like you have a database issue, try this
1. Export an ADIF file of your complete logbook
2. Create a new database
3. Import the ADIF file into the new database but ensure that you select option 1 'Apply quality check corrections'
4. Do another rescan references for the award
va3vf
Post by va3vf »
I'm pretty sure I tried that, and more. I don't give up easily. LOL
As I said, not a biggie, I can easily remember the State and bands still needed. :)
I'll try again later, but right now, I'm more interested in learning about the Win4 Suite discussed in the other thread.
Thank you very much for your help.
73 de Vince, VA3VF
