POTA / SOTA awards
Moderator: OE6CLD
cs7agh
Re: POTA / SOTA awards
Post by cs7agh »
SOLVED!
- Import references
- Activate countries
- Log
For some reasons, i thought Log4OM was already getting the references from POTA just like it does with SOTA
OE6CLD
Post by OE6CLD »
Hi Paulo,
Thanks for the swift update. Great that this issue has been solved. And no, there is no automatic update for POTA.
Enjoy the Parks on the Air activities from Portugal.
Claus
Claus, OE6CLD/DJ0DX/EI7JZ
I am sure other users would like the updated award file, perhaps send it to Claus for inclusion?
cs7agh
Post by cs7agh »
All i did was import the POTA CSV
https://pota.us/all_parks.csv
match the fields and it was done.
If i share the XML, does it help others?
https://we.tl/t-oHFjK27Xhr
Thank you all for the support and keep up the great work, best tool ever.
LB9EH
Post by LB9EH »
Hello!
I need a list of field settings for POTA!
I get error when I import All_parks.
I need help ASAP!
73 de Bjørn :D
The list is generated by the incoming file and the available matching fields are displayed in the manager.
The previous poster CS7AGH found it easy to do so..............
What are you doing differently?
Where/how are you trying to import the file?
Did you read the user guide about this?
