Telnet Cluster
g7fkj
Telnet Cluster
Post by g7fkj »
Just turned my pc on and the telnet cluster does not appear to be working the connect button is greyed out with only the DISCONNECT button available. It wa working yesterday...
Yaesu 450D
Windows 10
Sandpiper MV10 Aerial
Regards
Colin
Re: Telnet Cluster
Did you try disconnect and then reconnect?
What version of the program are you using? Help/About shows the version
Which cluster do you use?
g7fkj
Re: Telnet Cluster
Post by g7fkj »
Hi Terry
1.11.5.0, I got t working but do not know how..clicked on Sun and Moon buttons and it fired off again, it is the cluster that is set up in Log40M it says Telnet Cluster. It is still working OK.
Cheers for thr responce
Regards
Colin
G7FKJ
Yaesu 450D
Windows 10
Regards
Colin
Re: Telnet Cluster
Colin,
The cluster might have been down I suggest you use GB7MBC as it is local
