Hi Daniele,
Long Path rotator control is not working anymore
LP Rotator Control
LP Rotator Control
73 de XV9BPO Greg
Re: LP Rotator Control
Did you use pstrotator?
Nothing has changed on our side... It's probably something on pstrotator side...
Yeah using pstrotator.
Was working before and not anymore.
Hum dunno
Hum dunno
73 de XV9BPO Greg
It's all enabled on Log4OM side? communicator is up and running?
did you check program log for errors?
if everything is ok it's probably something on pstrotator side
Yeah it is working cause short path is working ok only when i click LP it is going to short path heading
73 de XV9BPO Greg
Ok I just found the issue !
It was in PstRotator Log4OM setup was tracking callsign instead of azimuth
73 de XV9BPO Greg
There are some changes in PSTRotator in upcoming 1.21 release, to better support SteppIR and multiple antennas with different bearings.
