CAT survey. Please vote.
What software are you using for RIG integration (CAT) in Log4OM
OMNIRIG ONLY (HAMLIB doesn't works)
9
15%
OMNIRIG
46
78%
HAMLIB ONLY (OMNIRIG doesn't work)
3
5%
HAMLIB
1
2%
NO CAT
0
No votes
Total votes: 59
Post by IW3HMH » 29 May 2015, 20:54
Mantaining 2 different CAT software is heavily expensive, in terms of software integration, because we should keep the "minimum common set" of informations between both CAT systems, and sometime one is a limit for the other.
We have the feeling that Omnirig is working better and on a bigger set of rigs (seems to be more reliable) but i want to have a survey on what user have in their shacks. This will help us enhancing the CAT logic in Log4OM with more functions.
PB4FUN
Re: CAT survey. Please vote.
Post by PB4FUN » 29 May 2015, 21:11
Why not just use the way other programs are using, with direct RS232 commands e.g. like in N1MM logger ?
PB4FUN Meindert; Rig : Icom IC-9100 / Ant: Falcon OUT-250-B @4m AGL; 144 MHz 16 el @ 4m AGL; 70 cm 23 el @ 5 m AGL
CT1BXX
Log4OM Beta Team
Post by CT1BXX » 30 May 2015, 08:54
Hi Daniele,
Now that we talking about Cat, I would like to give two points to think about.
What do you think that via Omnirig it can pick up the Output power from radio and also the "S" meter?
I talked with Omnirig programmer, Alex, about it and he told me that it is possible making it via the log software. Of course it's just a "preciousness" perhaps exaggerated, but something interesting. Is a suggestion to think about.
73 Manuel Fernando CT1BXX
gi0hwo
Log4OM Beta Team
Post by gi0hwo » 31 May 2015, 06:32
Omnirig gets my vote.
Post by G4POP » 31 May 2015, 07:04
The guys that polled for the "Omnirig does not work"
Why does it not work?
Your rigs not supported
Rig is supported but it does not work
Other
Fully detailed explanations please
M0RSF
Post by M0RSF » 31 May 2015, 10:40
Omnirig to control two Yaesu FT817ND transceivers. Rig-1 for 6M, 2M & 70cm and Rig-2 for HF.
73 Chris M0RSF
G/QRP #07737 - Fists #15922
Post by DF5WW » 31 May 2015, 10:42
as is wrote in an older thread. I have tested my Icom IC-735 with Hamlib but don´t get it to work. IC-735 is supported by Hamlib. With Omnirig never have had a problem to connect to my "oldie" TRX :D :D
Another CAT software that works perfectly with my old rig was Flrig and my question in the other (vy old) thread was "is it possible to integrate Flrig into L4O as CAT software" ....
My reason for that questin was: Omnirig switching Band, Mode and Frequency when i doubleklick in the cluster but if i do that with Omnirig after a few seconds the MODE field was empty. In Flrig the mode was holding ..... I have checked out to connect Flrig to L4O but my CAT interface is connected via USB and uses a "virtual" COM so i can not use a COM port splitter. COM port splitters only can split hardware COM ports :? :?
73´s .. Juergen ... ALT-512 SDR (10W) , 50 m random wire at CG-3000 autotuner, Ailunce HS2 (20W and 5W VHF/UHF) to LPDA´s and different vertical´s ...
Post by G4POP » 31 May 2015, 11:51
M0RSF wrote:Omnirig to control two Yaesu FT817ND transceivers. Rig-1 for 6M, 2M & 70cm and Rig-2 for HF.
73 Chris M0RSF
Chris,
Are you saying that you cannot or that you can use Omnirig for two identical radios?
M0RSF
Post by M0RSF » 01 Jun 2015, 10:50
My apologies Terry I should have made myself clearer. I control two 817's using Omnirig without any trouble at all, it works fine.
73 Chris M0RSF
Post by IW3HMH » 01 Jun 2015, 11:33
PB4FUN wrote:Why not just use the way other programs are using, with direct RS232 commands e.g. like in N1MM logger ?
Mainly because this require the implementation of all (different) CAT protocols adopted in all rigs.
They're sending direct commands to rigs, the work that is actually made by Omnirig/Hamlib/FlRig
I've plans and a working prototype of a "log4om CAT" but it's still in standby due lack of time :)
