Log4OM communicator
Posted: 17 Jun 2013, 10:11
by g4lds
Im running latest version & when I open it, I get a window saying ""Log4OM Communicator Interface" I close it down Is this normal now??
Chris
G4LDS
Re: Log4OM communicator
Posted: 17 Jun 2013, 11:14
Hi Chris,
Yes it is a new part of Log4OM, we removed all of the external services from the main structure and provided a seperate Communicator module to handle all of that trafic which helps to keep the main program running faster.
If you are using Alerts, Rotator control, interfacing with external software like FLdigi etc. you must minimise the Communicator because closing the window effectively stops the external services.
Full information can be found on Page 18 of the user manual.
Posted: 17 Jun 2013, 12:02
by g4lds
Thanks Terry
As you might know I use Log4OM as a stand alone log/cluster tool!!
Hope all ok in sunny Burnham
Keep up the good work!!
Posted: 17 Jun 2013, 12:31
Hi Chris,
If you don't use external services like alerts then you only need to go to the options/services tab and stop the service and uncheck the Start Automatically check box, then the Communicator will not start when you open the program.
Posted: 17 Jun 2013, 12:36
by DF5WW
Hi Chris, if you don´t need the communicator go to "Settings/Options/Services" and uncheck the Autostart box. Then communicator won´t be started if you open Log4Om next time .... But if you need "Alerts" let him run. Don´t use 2 much ressources
