working DX means frequently working in split; Log4OM (through Omnirig) is showing
- VFO A as RX Frequency
- VFO B as TX Frequency
This is all fine; my problem is that the QSO gets logged based on TX Frequency, I would prefer to log it based on RX Frequency.
Can this be changed in setup ?
Marco HB9CAT
Logged Frequency is TX; can it be changed ?
Re: Logged Frequency is TX; can it be changed ?
No it cannot be changed by the user
You could of course display the RX frequency in your recent QSO list etc if you wish to?
The TX and RX frequencies are logged using the standard ADIF format
The TX frequency saved to ADIF field 'Freq'
The RX frequency is saved to ADIF field 'Freq_RX'
To enable the universal exchange of amateur radio data 'Amateur Data Interchange Format
- VK7XX
- Old Man
Marco, I can overcome this problem by swapping the TX / RX vfo's (IC-7800) . I either swap and use VFO B for TX (or RX depending on how your radio works) .... or I swap VFO's immediately before logging the QSO. works for me & saves me editing the contact.hb9cat wrote:Hi,
Marco HB9CAT
John
