Save mode
ct1dbs
Save mode
Post by ct1dbs »
Hi
Is it possible to save the mode to be the displayed mode next time I open Log4OM ?
For instance, I work CW 99% of the times, but every time I open Log4OM it will display SSB instead of CW.
Thank you for your hard work. Log4OM is the nicest logging software! :D :D :D
73 de Pedro, CT1DBS
Re: Save mode
No Pedro the default is hard coded into the program but version 2.0 may allow a user choice
G4AON
Re: Save mode
Post by G4AON »
On the same theme, the drop down lists of Sent and Rcvd reports and modes can be edited, but when there is an update they revert to "standard" with endless unused clutter.
Could these parameters be edited once and saved in an "ini" type of file? It spoils the program having too many choices when most of us don't use many modes or send reports like 577 or 596...
73 Dave
Re: Save mode
If you save the modified modelist.csv as Modelist_user.csv it will not be overwritten by a fresh install because all 'user' files are ignored
