ADIF 3.0.6 approved ....
... including the new Modes like T10, FT8 ..... http://adif.org.uk/306/ADIF_306.htm
Think that we have to check for a new TQSL configuration in the next days so that we can stop
to load up those modes as "DATA" ...
Re: ADIF 3.0.6 approved ....
I was prompted to update my TQSL app when I turned it on today. Very quick update. I've not done any FT8 so can't speak to that. Only dabbled a bit with JT65.
Yes, cofiguration update to 11.1 was prompted. FT8 and T10 uploads are working.
If anybody has made own ADIF definitions for FT8 and T10 in TQSL please delete
and reupload all FT8 and T10 with the correct mode (not as DATA) ....
G4DWV
Post by G4DWV »
Doesn't doing this result in copies of BOTH contacts?
73 de Guy G4DWV 4X1LT
Hi Guy,
yes. But if you don´t reupload and ARRL will install a WAS or VUCC for this new modes
only these matches counting which use the correct mode. So DATA will not matching any
FT8 or T10 contact.
