Retain this setting?
Re: Retain this setting?
Post by KD0ZV » 18 Dec 2018, 13:09
Yes, they work as anticipated Terry. The only confusion is when you start the cluster and have remove worked countries checked you are seeing all these spots for countries you have worked.
Unchecking the remove worked countries and rechecking it refreshes things and shows correctly. Or it appears if I just wait it out for several seconds the unworked countries will drop off.
