Yes, and later restarted Windows for other reasons.
The VE7CC remains in the server list even though its not in the text file.
Cluster Server list
Re: Cluster Server list
Check if you previously created a cluster_user file, if so delete it
Terry, did you see the cluster user file in my screenshot?
I edited the original. So now I am just down to a working cluster and skimmer. But VE7CC still shows up.
Like I said, delete the user file then check what is in the default file
That works. There must be some bug with that??
I deleted the user file and let it regenerate off the original and then replaced the contents of cluster_user with just CWS and a working cluster and seems to be fine now.
