In the cluster statistics display, the latest version, the definitions are:
1) A blank in the band/mode means "Not Worked" this band/mode
2) A red "X" means band/mode "Worked but not confirmed"
3) A gray "check mark" indicates band/mode "Worked and confirmed"
The green strip indicates the band the rig is currently set too.
Further enhancements in this regard are in the works.
Cluster Statistics display
Re: Cluster Statistics display
Documented in the user guide page 37 with illustrations.
