V 1.4 Update Procedure
WA2SQQ
Post by WA2SQQ »
I just saw the notice that v 1.4 was released. I saw another discussion on an Italian language forum that in order to upgrade, your QSO's should be backed up, and manually imported. Did I understand the translation correctly?
Re: V 1.4 Update Procedure
While it is ALWAYS best practice to do a backup you can just install 1.40 over the top of your existing install, you shouldn't lose any data
