Locator Square Mapping
Re: Locator Square Mapping
As it stands now I use http://wg7j.reinalda.net/gridmapper/gridmapper.php and upload a copy of my 6m log into it, it then plots those grids onto Google Maps.
- grid mapping (Copy).jpg (194.95 KiB) Viewed 8621 times
If something like that could be incorporated into Log4OM constantly updating each time a grid is worked and flagging up as a new grid if that happens to be the case.
Also, once a locator grid is entered into F1's "Locator" field this should be the point SP/LP beam directions and Distance is derived from....over-riding the current default bearings and distance.
i'm experimenting right now with gridsquare mapping in google maps...
nice screenshot, good as reference
Please be aware that all grid squares need to be displayed, regardless of being already worked, so that the user can see at a glance if he/she requires a particular square. It is not sufficient to just display worked squares.IW3HMH wrote:i'm experimenting right now with gridsquare mapping in google maps...
Each square needs to display the locator reference whether worked or not
Worked squares should be completely coloured not just displaying a X or check mark
Map definition does not have to be very high, in fact high definition terrain and satellite maps become confusing to the eye
The CIA/NOAA provide free downloads of very good maps for this purpose, these are the ones Simon used in Mapper
Resolution needs to be to 8 digits - 6 will not do because the UHF and microwave guys need greater accuracy
Personally, I would only like to see major grid fields (first 2 letters such as IO), or 4 digit fields (such as IO91) plotted on a world map. I don't know of anyone that collects and plots 6 digit fields?
73 Peter G3ZSS
73 Peter G3ZSS
73 Peter G3ZSS
Peter,G3ZSS wrote:Personally, I would only like to see major grid fields (first 2 letters such as IO), or 4 digit fields (such as IO91) plotted on a world map. I don't know of anyone that collects and plots 6 digit fields?
73 Peter G3ZSS
It all depends on the users interest
For me the locator is totally irrelevant I am only interested in Islands and countries
The 6 meter man possible wants two or maximum 4 digits
2 meter guys definitely need six digits
UHF and Microwave aficionados want six or eight digit
We provide software for all OM so we need to please everyone
When we develop this we will include a user display choice of 2, 4, 6 & 8 locator digits but if we don't design for eight now then we cannot provide choices to suite all tastes later.
It's similar to designing a logbook that only uses the ADIF fields call, band and mode, if we did that then we could not add extra data for the user! we include all ADIF fields and then the user can display and use the ones he is personally interested in
links to those images?
how about using google maps for this? i think it's better...
Google maps is OK if you can do a world wide overlay of the grid squares but as I said earlier the detail in GM confuses the eye
I will Skype you the links to the CIA/NOAA maps in a few minutes
got it...
anyway mapping over google maps is easier than mapping coordinates over a couple of non geo-referenced images...
I will probably start with GM, then we will can see if there are further needs or opportunities on making this work embedded into log4om
For the U.S. users, you might consider this mapping as part of the VUCC award.
By this I mean, when viewing the VUCC award a selection to display the grid squares worked, confirmed and credit granted.
