My Manuel doesn't want to load up from the program anymore,Can you tell me what could be wrong?
Manual
Re: Manual
Have you tried to uninstall your Adobe Reader and using another PDF-Reader instead of it ?
Have had the same problem a lot of month ago that the manual wasn´t opened from the
Log4OM menu. In my case it was a problem with the Adobe software. Meanwhile i have
changed to another PDF software.
73´s .. Juergen ... ALT-512 SDR (10W) , 50 m random wire at CG-3000 autotuner, Xiegu G90 (20W HF TRX) as portable Radio. Also TS-790E (40 W) for VHF/UHF with X-50 vertical and Duoband 4-Element LPDA.
Re: Manual
Thanks for the help,I setup W
indows to use Chrome as my PDF and it works now.
Thanks Rich
73 KB1FGC
73 KB1FGC
