I uploaded all of my QSO's to LoTW successfully. All QSO's showing on LoTW website. However, when I try to download for confirmation in Log40M, it comes back as 0 qso's downloaded.
Any suggestions?
Thanks!
LoTW Download??
Re: LoTW Download??
Sounds like you did not use the date range? Unless none of you QSO's were matched at LOTW or you did not allow sufficient time for LOTW to match them
Re: LoTW Download??
It's been about 8 hrs since I uploaded my logs and have 122 confirmed on the LOTW website.. however, when I try to download the files using several different dates in the date range, it indicates "ADIF Document Parsed: 0 QSO Found"
I've tried running dates back to my license date in Oct of 2012....
Maybe I should wait longer? I appreciate your input. Thank you
Re: LoTW Download??
KB3ZHX wrote:It's been about 8 hrs since I uploaded my logs and have 122 confirmed on the LOTW website.. however, when I try to download the files using several different dates in the date range, it indicates "ADIF Document Parsed: 0 QSO Found"
You should see something similar to the screenshot below - Note the QSL Received Since setting and messages in pane.
If not please post a screen shot of what result you get.
Sometimes at a weekend LOTW can take a long time to provide the feedback.
- Untitled3.jpg (81.27 KiB) Viewed 5855 times
Re: LoTW Download??
Hi Terry, I appreciate your quick responses.
Here's what I'm getting... Still zero qso's:
- ScrnCapture_01.jpg (39.89 KiB) Viewed 5848 times
Re: LoTW Download??
I have it! I noticed from your screen shot that your call sign was in all caps... I changed mine to all caps and it worked! Thanks for all your help.. hopefully this thread will help anyone else who encounters this.
Best 73's Brian
Best 73's Brian
- ScrnCapture_02.jpg (57.89 KiB) Viewed 5848 times
