QSL label layout
GM4OSS
QSL label layout
Post by GM4OSS »
Hi
I am now able to print qsl labels with Dymo 450 reel printer with label 11356, 89mm x 41mm OK.
My concern is that while it printed of the qso details correctly the text is very small and crammed into middle of the label and the last line, 73 de XXXXXXX was missing too.
Is there a way to increase font size and is it possible to add an ADIF field eg "Contest"?
Is it possible for the user to make any other changes to label layout?
Thanks in advance.
Steve/GM4OSS
Re: QSL label layout
1. You can change the font size in the final label print window - It's underneath the label selection field
2. No you can't add fields or change the layout
GM4OSS
Post by GM4OSS »
Terry
Thanks for the info all OK now.
Is there any plans for the future to allow more user control of label layout?
Steve/GM4OSS
Possible but it's not high priority
G7CQW
Post by G7CQW »
Hi, I use a Dymo 400. Once I have selected the QSO's I export them as a CSV file, you can then import them into the Dymo software and edit the layout as required. Don't know if that helps.
Tony.
