Hi All
I have just updated to ver 1.22 and I can't remember how to alter the tabs on the cluster,
I had it done on the older version I used,
I want to move the bearing tab to where the rank is,
Trevor
EI2GLB
Cluster Layout
Re: Cluster Layout
Trevor,
You have never been able to change the column order in the cluster tab, the request for a layout button has been on Mantis for a couple of years
Re: Cluster Layout
I was sure I did must have been dreaming,
thanks for the heads up Terry,
Trevor
EI2GLB
Trevor
EI2GLB
Re: Cluster Layout
EI2GLB wrote:I was sure I did must have been dreaming,
Trevor
EI2GLB
Mantis entry of 3 November 2012
0000196: User configurable cluster screen (F9)
Description Provide the user the ability to change the layout of the main cluster screen (F9).
Re: Cluster Layout
Yeah, what a great mantis... we did a lot of work since that one
Ok ok...
Ok ok...
