After running Log4OM, I have to manually stop Omnirig if I want to run anything else with my rig.
Is there a means of shutting down Omnirig on program exit? Perhaps an option "tick box" as maybe not everyone would want to shut it down.
73 Dave
Shutdown Omnirig on program exit?
Re: Shutdown Omnirig on program exit?
I can "kill" omnirig, but usually is not an intended function because will also stop every other software connected to omnirig
Perhaps with an option box?IW3HMH wrote:I can "kill" omnirig, but usually is not an intended function because will also stop every other software connected to omnirig
I needed to update the firmware on my K3 and had to manually shut down Omnirig, not hard, but a little messy.
I am intrigued by this?G4AON wrote:After running Log4OM, I have to manually stop Omnirig if I want to run anything else with my rig.
73 Dave
My Log4OM set up uses Omnirig with an Icom 7600 as rig 1 and an Icom IC7100 as rig 2
When I close Log4om the com port is released for both radios and I can open any other software like MixW, HRD, DX Labs etc. using the com ports that ere just a moment before being used by Log4om/Omnirig
Perhaps you could provide a description of your set up and what other software you run that requires you to manually close Omnirig
I am assuming that you have got the latest version of Omnirig installed?
Hi Terry
Sorted! I also run CW Skimmer which shouldn't use Omnirig as it's not controlling a rig. However, CW Skimmer does start Omnirig... So, closing Skimmer and Log4OM also shuts down Omnirig.
All is well, I'll go back to sleep now!
73 Dave
73 Dave
