I wanted to set filter to mark 90IARU stations using different colur to make them easier to spot.
I opened custom filters for Cluster and set
Description: IARU
Colour background: yellow
Expression: (IARU)
After I test using for example VK90IARU call it shows OK.
I saved that and checked new filter to be active.
Nothing happens in cluster window. IARU stations are not colored.
Tried to restart application, did not help.
What am I doing wrong?
Setting custom station color in Cluster window
Re: Setting custom station color in Cluster window
This will only work if the call is displayed in the 'Notes' field not the call sign field
That axplains why it does not work.
Well, then this might become feature request
