LOTW Help
KA5MWB
LOTW Help
Post by KA5MWB » 18 Jun 2013, 01:35
hi i try upload a few qso to lotw had erros]
it said. operation completed with erros
error starting tqsl signature file the system cannot find the file specified
Re: LOTW Help
Post by G4POP » 18 Jun 2013, 06:27
Have you tried using TQSL manually? And does that work OK?
Alternatively you have not set the Path to the TQSL .exe file correctly in LOG4OM options
KA5MWB
Re: LOTW Help
Post by KA5MWB » 20 Jun 2013, 04:41
ht terry
it did not work in manually
it said info adif file succesfully
info starting tqsl signature file
VA3AG
Re: LOTW Help
Post by VA3AG » 20 Jun 2013, 06:15
KA5MWB wrote:ht terry
Do you have an LoTW certificate?
If you do, you need to point Log4OM to where you saved the certificate.
good luck
Aldo VA3AG
Re: LOTW Help
Post by G4POP » 20 Jun 2013, 06:52
First make sure you have downloaded and installed Trusted QSL you get that from the LOTW web site - Version 1.14 is the latest.
Once it is installed you need to tell Log4OM where to find it
Set the Path to the Trusted QSL .exe file correctly in LOG4OM options on the external logbook tab
LA9FFA
Log4OM Beta Team
Re: LOTW Help
Post by LA9FFA » 20 Jun 2013, 09:11
Also remember to set "Station Location"
73`s De Rolf LA9FFA.
Member of: NRRL/ARRL/LA4O/LADX Group.
Honor Roll #Mixed #CW #8 Band DXCC.
KA5MWB
Re: LOTW Help
Post by KA5MWB » 21 Jun 2013, 23:33
i down load 1.14
how do you set the path to trusted qsl.exe file
LA9FFA
Log4OM Beta Team
Re: LOTW Help
Post by LA9FFA » 22 Jun 2013, 03:33
Settings --> Options --> External Logs --> LoTW Settings
Re: LOTW Help
Post by G4POP » 22 Jun 2013, 07:15
KA5MWB wrote:i down load 1.14
Have you applied for and received your TQSL Certificate from the ARRL/LOTW??????
KA5MWB
Re: LOTW Help
Post by KA5MWB » 22 Jun 2013, 14:44
yes terry i have the certificate
now when i upload to lotw manually and sign it it send automatic to lotw
what do i need to do to have log40m to up load to lotw automatic?
