QTF Heard Island
pa2kw
QTF Heard Island
Post by pa2kw »
I just entered Heard Island in the log entry field (to check antenne direction for beverage) and noticed 180 deg.
My feeling says : this is wrong (just good guess it should be close to 135 or so from PA land)
Is there some "error" on the position of Heard Island in the database or am I doing something wrong?
73's, Evert PA2KW
Re: QTF Heard Island
Evert,
My guess is that you did not have the correct grid locator either from your online lookup or manual entry, see my screen shot below
VK7XX
Post by VK7XX »
There appears to be another problem with Heard Island. When I type in the call that Terry used above, the beam headings and map are correct, but the IOTA is missing. I did a search and is seems that Heard Island is AN-003 however, there is no AN-003 in the IOTA drop down list (F2)
If AN-003 is correct for Heard Island, it needs adding in to the drop down list ASAP. If I am lucky enough to work Heard Isl, I guess I can edit the contact later but it would be better if it did it at the time. Can I add AN-003 to the Log4OM list manually ??? if so, how please ?
John
VK7XX
PS, I have just downloaded the latest IOTA database, AN-003 still not there)
Then blame IOTA because that's the list we use, if they don't include it then we cant display the reference
VK7XX
Post by VK7XX »
G4POP wrote:Then blame IOTA because that's the list we use, if they don't include it then we cant display the reference
thanks for your reply Terry. yep, thats exactly what I am doing, and the reason I asked if there was a way to add it in myself. I have now sent through an email to RSGB .
cheers
John
Problem is John if you modify the file the next IOTA download will overwrite it so your back to square one
John,
Seems were buggered whatever we do
On QRZ.com VK0EK has added the AN-003 reference but not the locator so we get the correct IOTA but the map is screwed
On HamQTH there is very little detail
On QRZCQ the standard information is available but neither IOTA or Locator
VK7XX
Post by VK7XX »
G4POP wrote:John,
yep, know that feeling... geez I hate computers. Would you believe... when I started the logging program again today, it now shows AN-003 in the list... duhhhhh. I tried it 3 times yesterday, even rebooting the machine after installing the latest data and it just did not show.
not much more I can say.... thanks Terry
John
pa2kw
Post by pa2kw »
Hello Terry,
Thanks for the reply.
If I read your first answer I conclude that the QTF is only based on a QTH locator and not on a DXCC when the locator is missing?
(I would suggest first reference would be the locator but when missing based on a DXCC, probably less accurate but better then nothing).
73's, Evert PA2KW
N6VH
Post by N6VH »
When I type in VK0EK, it shows the country as Antarctica, and AN-003 is not in the drop down list. However, if I change the country to Heard Is., then AN-003 is in the list.
Jim N6VH
