Page 2 of 2
Re: DXCC Award administration - help needed
Posted: 25 Jul 2013, 15:48
by dk2lo
your description works fine for all QSOs already in V (validated status). These are the LOTW confirmed QSOs.
Unfortunately the credit granted update does not work for the rest.
The QSOs confirmed wirth QSL card are in C (confirmed status) and refuse to change the status using your instructions. I managed to change the status into S (submitted) but also any attempt to change this status further into G (granted) does not work.
Is it possible that this is a software bug? I am on the latest release 1.14.0.0.
Posted: 25 Jul 2013, 15:54
The QSL card status of confirmed etc has no connection to the award status of submitted or granted apart from not being able to submit a card for award credit unless the card is confirmed.
Works perfectly for me, are you reopening the statistics window after your update? the change of award status will not show until you do because the window does not refresh automatically.
Posted: 25 Jul 2013, 17:39
by dk2lo
Does not work for me. I tried reopening the statistics, I used the refresh option in the awards window, I closed LOG4OM and restarted it but the changes for credits for C-status QSLs are not updated. With V-status everything works as expected ....
I am able to change the C QSLS to the yellow state (Submitted) but from this status there is also no update possible to get it in V-state, which would be the gate to the solution because changing V into G works here.
I have no idea what is going on. First I will give up here and hope for the LOTW upgrade of the ADIF files and the new version of LOG4OM which uses this new ADIF data field. In the mean time I try to convince ARRL to deliver the same service to credit granted QSLs. Then everything should work automatically. There is no real hurry because I have my DXCC standings and details in LOTW available.
Thank you for your help and sorry for any inconvenience.
Posted: 25 Jul 2013, 18:52
by K7PT
In the QSL Info status tab of the QSO, set QSL RCVD= Verfied
See attachment.
Chuck
Posted: 25 Jul 2013, 19:29
by dk2lo
Hi Chuck,
that is the solution! I did not find this button. After changing this to V everything works now. Thanks you very much!!
Posted: 25 Jul 2013, 21:16
dk2lo wrote:Hi Chuck,
Which is what I said in my last post!
a
Apart from not being able to submit a card for award credit unless the card is confirmed.
Posted: 25 Jul 2013, 22:36
by K7PT
G4POP wrote:dk2lo wrote:Hi Chuck,
a
Terry- I think the confusion is above "unless the card is confirmed" should read "verified"
