Hi...
Sometimes, when I open Log4om I find that VFO B is not with A . . . My Rig is not in Split... I would like to know how to change from Log4om because sometimes I am running in simplex and all QSO are logged with VFO B ... and it is not correct...
I hope anybody understand me.... hihihihihih
Tnx in advance
VFO A B
Re: VFO A B
It really helps if you provide more information
Windows version
Log4OM version
Make and model of radio
Interface cable type between radio and computer
Windows version
Log4OM version
Re: VFO A B
I use a Yaesu FT 950 with SCU 17 Interface (Yaesu) with OmniRig.
I have 1.25 v for Log4om ... with Windows 10
Normally, I have not problems... I change freq with double click, etc . . . Only this problem...
This problem do not happens every time... Sometimes I switch on my Rig and It is OK, sometimes no...
Tnx
Jose EA5IDQ
Tnx
Jose EA5IDQ
EC6DX Balearic Islands
Re: VFO A B
Sounds like the polling rate in Omnirig is set to low try changing it to 100 and use a baud rate above 9600
Re: VFO A B
Hi...
I change to 9600... I was on 4800 . . . but continue same problem... I enclose my Omni Rig options... Tnx
- 20160602_110834_resized.jpg (39.11 KiB) Viewed 4401 times
Re: VFO A B
As I said use a higher baud rate - Above 9600 - 19200 ?????
Change the Poll Interval from 500 to 100
Re: VFO A B
Terry... You are the Best... It seems that It is working good... I will test during few days... Fantastic... I will donate some €€ to support this fantastic Software... I am very very happy... and Of course... continue learning and reading in Forum...
73 de Jose EA5IDQ
73 de Jose EA5IDQ
