Here is my scenario:
I import an ADIF file daily from another app (all CW).
I also enter QSOs directly into Log4OM (generally SSB).
I have the default QSL status set to "Requested"
I go into "Label Print" and chose to print "Requested" QSL labels and ONLY the ones that were imported show up in the list. There is no way I can get the ones directly entered into Log4OM to show up in the label list. Even is I enter a new QSO in Log4OM after the import, only the imported ones will show up in "Label Print."
Any ideas what I need to do to fix this issue?
Thanks,
Roger
AE4RM (formally KG4GGG)
Cannot Print Labels for Contacts
Re: Cannot Print Labels for Contacts
Have you checked that the QSL status of those QSO's logged in Log4OM have the correct QSL sent status?
Found the problem. It was in the Station Callsign. The ones imported have a blank call sign entry, the ones I enter have my call on it. I just have to change the call sign to get them to print.
Thanks for putting me on the right track.
Roger
Roger
