Missing "worked" "worked same band"
Installed Log4om on a second computer ,but now wen i put a (worked) callsign in the callsignbox nothing give me the notice/remind for "worked" or "worked same band" .........what do I wrong ,please help me,thanks from ON3FZT
Re: Missing "worked" "worked same band"
Did you transfer the logbook database (The SQLite file) that contains all of your old QSO's to the new computer?
Can you see all of your old QSO's in the recent QSO tab?
YESG4POP wrote:Did you transfer the logbook database (The SQLite file) that contains all of your old QSO's to the new computer?
There is no reason that it should not work and no setting that starts it working or stops it working
Have you tried re-installing the program and are you certain that you are running Log4OM as an administrator (See user guide for details of how to do that)
HelloG4POP wrote:There is no reason that it should not work and no setting that starts it working or stops it working
reinstalled again,buth the option "run as an administator" is not available in Windows xp,so.......what can I do now??
Do the following:
1. Send me a support request (Help/Send bug report) INCLUDE THE ADIF FILE
2. Email to g4pop (AT) arrl.net
DO NOT POST THE FILES ON THIS FORUM FOR SECURITY REASONS
Send you the files tomorow by email,for now many,many thanks for your help,73 from on3fzt,Luc
All files send by email but..... after sending the email and after a new/other look in my settings------>
problem solved!!
settings/options/setting1:external sources:use qrz.com FORGOT TO FILL IN my user id and password
many thanks for this wonderfull logbook and for the very fast help
Luc
ON3FZT
problem solved!!
Luc
ON3FZT
This should not be an issue.
Can you check in the cluster screen settings tab what kind of reporting is enabled? (worked/qsl confirmed/eqsl confirmed/lotw/lotw+qsl)?
