Hi all,
Did I missing something? After adjusting map size ...cluster panel size on the right, choosing sort dc cluster only phone, after restarting log4om getting default layout size again? Should I run in admin mode or missing somewhere save layout size?
Regards, Kes-m0pkz
layout size after restarting
Rigs: FLEX-6300 Ant: 6 band hexbeam (by SP7IDX).
http://m0pkz.co.uk/
http://m0pkz.co.uk/
Re: layout size after restarting
On main User Interface?
Yes, size is not saved at this time because i have to find a smart way to save panel size without coding each single event to a variable that will be saved into the config file... or have had no time to do
http://m0pkz.co.uk/
http://m0pkz.co.uk/
If you click the floppy disk save settings button at the bottom of the filter window your preference for phone only will be retained between restarts.m0pkz wrote: choosing sort dc cluster only phone, after restarting log4om getting default layout size again?
Log4OM should always be run as an administrator to be able to use all of the features, we point this out in the user guide and Quick Start Guide!Should I run in admin mode or missing somewhere save layout size?
Kes,
There is a shareware utility that could help you. I use it in Win 7 as that OS seems to have issues remembering windows settings. I have no problems with Log4OM opening the way I want it.
Check it out http://www.desksoft.com/WindowManager.htm.
Happy New Year to Lele, Terry and everybody else here.
73 de Guy G4DWV/4X1LT
Thank you all for replies!!!
Kes-m0pkz
Kes-m0pkz
http://m0pkz.co.uk/
http://m0pkz.co.uk/
