Back when I started using Log4OM, I imported my entire log from HRD going back to 2009. right now, I have gone into tab f8 and set the display limit to 0 but the log only shows contacts going back to 2013. So what am I doing wrong??
Paul
kc2nyu
Display Limit
Re: Display Limit
Try setting the limit to a number greater than the number of QSO's in the logbook and see if that then displays the older ones
Re: Display Limit
Terry - thank you so much, that did the trick, setting to a number higher then total QSO's in log.
73 & have a great day
Paul
kc2nyu
Paul
kc2nyu
Re: Display Limit
kc2nyu wrote:Terry - thank you so much, that did the trick, setting to a number higher then total QSO's in log.
Paul
kc2nyu
I have a feeling that you entered an Oh 'O' instead of a zero
Re: Display Limit
I certainly may have
Paul
kc2nyu
Paul
kc2nyu
