hi
i love your log4mm great need to link to dm780 and will the best loging system in ham radio thanks
i have one bug i can not get to save dm780 qso in log4m or hrd logbook
thanks
c.l.beaver
ka5mwb
save qso
Re: save qso
Have you followed the instructions in the user guide?
Just tested and both methods work fo me
Re: save qso
hi terry
method1 load qso to hrd log book
ok will not load to log40m to log book
i like method 1 i wll work on method 2 some more ok
thanks
terry
ka5mwb
thanks
terry
ka5mwb
Re: save qso
Sounds like Communicator may not be configured or is not running properly.
1) Check that Log4OM is running "as Administrator" if you're using WIn7 or Win8. This is necessary for Communicator to work correctly.
2) Second, check that you have configured Communicator properly (Pages 134 and 135 in the manual), not just DM780 (pages 136 and 137).
Dave
K3DCW
Dave
K3DCW
K3DCW
Elecraft K3
Elecraft K3
Re: save qso
hi terry
i am runing a kenwood ts 590s and window xp and hrd 6.1
method 2
said transmit failed connection. and to check that the hrd server was started and go to tool and select ip server
thank you all for hlep
ka5mwb
method 2
ka5mwb
Re: save qso
KA5MWB wrote:hi terry
method 2
ka5mwb
You must have the HRD IP server running to start this go to the tools menu in the main rig control window of HRD and select IP Server, start the service and check the box that says auto start or similar
Re: save qso
If Terry still has problems then I hope someone else can help him because I am going on Vacation so can't respond
Re: save qso
hi terry
will not working on 1or2 method
thanks
ka5mwb
thanks
ka5mwb
