LOTW synchronization
K0HB
Post by K0HB » 19 Aug 2013, 21:38
When I try to download new QSLs from LoTW I have no success.
The program (Log4OM POST OFFICE) gives the following results:
Begin ADIF generation request
ADIF request accepted
ADIF document downloaded
ADIF document parsed: 0 qso found
Then a message box, "Operation Completed"
In other words, the process returns no new QSL from LoTW, even though I know that there are some at the LoTW site that have not been downloaded.
DE Hans, KØHB
"Just a boy and his radio"
Superstition Trails ----> http://OldSlowHans.com
K7PT
Re: LOTW synchronization
Post by K7PT » 19 Aug 2013, 22:27
What is the starting date you want to download from, how many days.
If you had a new LOTW match 3 days ago and set the staring date of 2 days ago, it will return zero (0) matches because you have no new matches in the past two days.
You can set the starting date back as far a you want and it will download them not harming a thing. :roll:
K0HB
Post by K0HB » 20 Aug 2013, 03:17
Well, I poked around and poked around and poked around with no positive result.
So decided to re-enter all the parameters, one at a time.
When I re-entered the password, suddenly the process worked, so seems I had a bad password.
Might want to look at the code, because that should have spawned "bad password" error. Instead it just reported "Process Completed".
DE Hans, KØHB
Post by IW3HMH » 20 Aug 2013, 10:11
I will check that but I will give all informations that tqsl gives to me.
What version of tqsl are you using?
K0HB
Post by K0HB » 20 Aug 2013, 17:27
Last version released.... 1.14.xx
DE Hans, KØHB
K0HB
Post by K0HB » 01 Sep 2013, 02:36
I am now using tQSL v 2.0 Beta RC2.
When UPLOADING to LoTW, everything works as expected.
When DOWNLOAD from LoTW, you must enter your password (even though it looks like one is saved in default). If you do not enter a password, the function seems to execute, but does not, and no error is raised.
DE Hans, KØHB
Post by IW3HMH » 02 Sep 2013, 07:32
I need to make some tests on that... it's possible your saved password is not correct in Log4OM settings?
