LOTW: Error 13
G4IUA
LOTW: Error 13
Post by G4IUA »
Everything has been running smoothly for ages. However I now have a problem when uploading to LOTW. As far as I am aware downloading is OK. The dialog box reads:
Messages from LOTW:
TQSL Version 2.2.2(v2.2.2)
Signing using Callsign G4IUA, DXCC Entity ENGLAND
No records to upload
Final Status: Unknown (13)
Unrecognised answer from TQSL. Value is 13
OPERATION COMPLETED
Any ideas what is causing this?
Jeff - G4IUA
Re: LOTW: Error 13
Hello Jeff,
could be possible that your TQSL version is outdated. Latest version is v2.3.1.
Download and install the latest TQSL and try again.
G4IUA
Re: LOTW: Error 13
Post by G4IUA »
Thanks for the suggestion Jurgen. I've upgraded to 2.3.1 of TQSL and it now reports the new version. However...still no joy!
What do you think I should try next?
Jeff - G4IUA
G4IUA
Re: LOTW: Error 13
Post by G4IUA »
Hold fire...I need to investigate further and I'll report back.
Jeff
Re: LOTW: Error 13
You could also look at the Yahoo reflector for LOTW. It is quite active and lots of good support. I think I've seen others having problems similar to what you have noted.
Re: LOTW: Error 13
Has your certificate expired???
G4IUA
Re: LOTW: Error 13
Post by G4IUA »
All good now. I can only assume that updating the version of TQSL sorted out the problem, as the certificate was valid. I'll also look at the LOTW reflector to see why others have experienced similar problems.
Thanks to all
Jeff - G4IUA
