Problem after importing ADIF file
Posted: 11 Sep 2013, 11:48
by G8AJM
I’m a very new user of Log4OM having enjoyed using it for about a week, after which I had to perform a (scheduled) rebuild of the PC. First however I exported an ADIF file as I presumed that would be how to get the QSOs back into a new install of Log4OM. On firing up the new log, I created a new DB and imported the file and everything looked OK. During the rebuild I had a few QSOs which I kept a paper record of and once the new log SW was loaded and configured, I tried to add them into the log using the normal entry form. As I was making the first entry everything seemed to be working (QRZ info, map, distance, etc.) but when I hit “ADD” I got the message “Error saving QSO” “Unable to open the database file”. As far as I can tell everything else looks fine and the bottom right of screen is showing the path to the SQLite file.
I’d be very grateful if someone could point me in the right direction.
Chris
Re: Problem after importing ADIF file
Posted: 11 Sep 2013, 12:02
by G4NVB
I think you will find that you have to create a new log file before doing the ADIF import.
Posted: 11 Sep 2013, 12:57
by G8AJM
Thank you.
Does that mean that after I created the new database I should have made at least one new entry manually and then imported the file? In other words does making a normal entry first create a new log file?
Chris
Posted: 11 Sep 2013, 14:50
by G4NVB
You need to create a database so that you can add log entries or import entries. You can import adif into an empty database.
Posted: 11 Sep 2013, 14:58
by G8AJM
That worked!
Many thanks.
Chris
G8AJM
Posted: 11 Sep 2013, 17:27
by G4NVB
You are welcome, enjoy Log4OM.
Posted: 11 Sep 2013, 19:54
by IW3RAB
G8AJM wrote:That worked!
Many thanks.
Chris
G8AJM
In addition to G4NVB reply plese verify that last version of english pdf manual is downloaded.
The last version by Terry G4POP is Updated: 05/09/2013 8:12 am (see first page).
goto Help --> Help --> English --> Force manual update
After popUp "Manual is available" you can read it from
Help --> Help --> English --> Open Manual
I recommend TO ALL reading the manual as it is a mine of information.
Enjoy Log4OM.
73 Sandro, IW3RAB
