Hi All.
Trying hard to get this to work.
Using com0com to create virtual com ports. Assigning one of them to omnirig and then pointing Log4OM to omnirig.
When I do this everything seems to work fine EXCEPT, the VFO on Log4OM is 100Mhz too high. (see attached)
Any thoughts or ideas?
Mike M0XMX
Integration with Win4Yaesu
- Capture.JPG (140.54 KiB) Viewed 1826 times
Re: Integration with Win4Yaesu
Are you certain that you don't have a transverter offset set in Log4OM Options/CAT & Cluster - default is 0.000 (=No offset)
