Can it be done? I'm having a hard time figuring this out. I know I can do this to the services. I need to upload my logs from 9/15/2016 to today. ADIF export then import into ClubLog?
ClubLog Bulk Upload
Re: ClubLog Bulk Upload
Easiest way. export the contacts in the date/time to ADIF. Login to clublog and use
the upload function. If i have trouble with my internet connection and some QSO
would´t be uploaded i do the same. On Clublog no QSO will be doubled when you
upload via ADIF.
B.t.w. If you have done this you can set the clublog sent date and status to "Y" via
the bulk editing feature.
upload via ADIF.
Danke schoen Juergen, that's what I was thinking I would have to do. The reason why I wasn't uploading was that of a bad password I had entered in the preferences.
Live n learn
73 from So Cal
Live n learn
73 from So Cal
