I have a delay as I click on the DX spot radio switch over the time of 5-25 s.
I use omnirig . Other programs works fine.
ic-7300 CAT problem- delay
Re: ic-7300 CAT problem- delay
Hello OM,
we have had no reported delay issues for the IC-7300 in the past.
Did you are using both programs with administrator rights ?
Are the settings in Omnirig are correct (e.G. Baudrate, Stopbits) ?
Only reported issue for the IC-7300 in the past was incorrect
switching to CW-R instead of CW but this can simply changed in
the IC-7300.ini file ...
Are you using Omnirig and if not you should do so.
Set Omnirig Poll int to 100
I'm using Omnirig, changing to administrator rights has not improved.
The bitrate is 19,200 because only the trx connection is set up just as the rest of the settings(bitstop etc) are correct as in other programs Loger32, JTDX, WSJTX- work properly.
I changed to 100ms - nothing improved .
Click on the spot and nothing happens sometimes after 30s interrupt, as it is on the same band it's faster
Send me a support request as detailed here http://www.log4om.com/log4om-support/ by email to g4pop (AT) arrl.net
Ok please email address ...
