Log4om & IC-7600
Log4om & IC-7600
Dear Sirs, I am having difficulty integrating my IC-7600 into Log4OM. I can only use Log in manual mode. I already configured it in IC-7600 (beta) mode but the band / mode / frequency are not recognized by the soft ... Can someone help me solve this problem?
Re: Log4om X IC-7600
Are you using Omnirig for CAT ?? If yes please update to the latest version of Omnirig.
Meanwhile there are 2 entries for the IC-7600. Once IC-7600 and second IC-7600v2 so
there is no "Beta" in the latest Omnirig.
Please install Omnirig with administrator privileges and Log4OM should also run with
administrator privileges too.
Most user issues with 7100, 7300, 7600 >>>>> is because they did not follow the Icom USB Driver installation guide and just plugged the usb cable in before installing the driver
The Icom instructions clearly state.................
NOTE: • NEVER connect the USB cable between the transceiver and the PC until AFTER the USB driver has been installed. • This USB driver is not supported by the automatic recognition system.
I have the IC7600 and Log4OM works without problems using Omnirig and the IC7600v2 ini file to provide display of both VFO's
See the Icom driver installation guide here:
http://www.icom.co.jp/world/support/dow ... Win8_0.pdf
Download the driver from here:
https://www.icom.co.jp/world/support/do ... 0/usb1_20/
Re: Log4om & IC-7600
I also run an IC7600 and it works fine only with Omni Rig.
I would suggest downloading a new copy and try it all over.
Ron N7RD
Ron N7RD
Best Regards,
Ron D. Smith N7RD
Ron D. Smith N7RD
