Loss of all settings
ZS6AI
Re: Loss of all settings
Post by ZS6AI »
I just switched on my PC and the LOG4OM programme opened as a new configuration again. I was using the programme this morning with no problem.
Terry, I have sent you my LOG directory via email.
Hello Guy, I’ve only logged into the forum now and seen your reply; sorry to hear you had the same problem, I wouldn't mind so much if it happened every 2-3 years but once a week is very frustrating!
>>I do regular HD clean ups
I run “Disk Cleanup” and “Disk Defragmenter”, the Window System Tools.
Thank you for your suggestion, I will run ‘chkdsk /r’ during the night and let you know the results.
73 Mike ZS6AI
Don't bother with the chkdsk routine it wont fix this and may cause problems elsewhere
You seem to have a corrupt xml file I have responded to your email with instructions
You could also try running the software as a portable install to Dropbox or Google drive, that way there is no permeant installation
G4DWV
Post by G4DWV »
How can chkdsk /r cause problems? I would really be interested to know.
73 de Guy G4DWV 4X1LT
G4DWV - Guy wrote: 21 Oct 2017, 17:20 How can chkdsk /r cause problems? I would really be interested to know.
Just lke CCleaner it sometimes archives sectors with information without moving it, but if you doubt that give it a try a couple of times and then watch your computer regularly crash or some programs stop functioning
G4DWV
Post by G4DWV »
G4POP wrote: 21 Oct 2017, 17:59
Thanks for the heads up on that one Terry. Never heard that before.
