WinKeyer <CONT_TX> macro not working ?
dk3dua
Post by dk3dua » 07 Oct 2017, 19:43
I try to use <CONT_TX> with "micro KEYER II" build in WinKeyer. Connection to com port is ok, sending normal text is ok, special functions like tune also ok, CW speed reading from keyer and setting also ok. But <CONT_TX> macro not, no number is transmitted, it does just nothing. Number is set in WinKey, I see in WinKey setup "next number 039" , and sending number with WinKey (direct, without using Log4OM) is also working.
What could be wrong ?
I use Log4OM macro
TU UR 5NN <CONT_TX>
and Log of keyer shows
Code: Select all
0043987633:  Log enabled, (urouter v8.8.2, micro KEYER II v6.11)
0043990051:  H-TX: 20 54      T
0043990051:  H-TX: 55 20 55 52     U UR
0043990051:  H-TX: 20 35 4E      5N
0043990051:  H-TX: 4E 20     N
0043990097:  H-RX: C4      [status: WAIT=0, KEYDOWN=0, BUSY=1, BREAKIN=0, XOFF=0]
0043990347:  H-RX: 20
0043990612:  H-RX: 54     T
0043991236:  H-RX: 55     U
0043991611:  H-RX: 20
0043992110:  H-RX: 55     U
0043992749:  H-RX: 52     R
0043993124:  H-RX: 20
0043993748:  H-RX: 35     5
0043994263:  H-RX: 4E     N
0043994762:  H-RX: 4E     N
0043995136:  H-RX: 20 C0       [status: WAIT=0, KEYDOWN=0, BUSY=0, BREAKIN=0, XOFF=0]
vy73
Thomas
DK3DUA
Re: WinKeyer <CONT_TX> macro not working ?
Post by G4POP » 08 Oct 2017, 09:22
You have set Log4OM in contest mode haven't you? only as you can see below it works fine for me
dk3dua
Post by dk3dua » 08 Oct 2017, 17:59
Tnx Terry, yes with contest mode it works perfect :)
And of course this mode is mentioned in Winkeyer chapter of the manual, but I overlooked it, sorry.
A vy cool feature to do some random contest Q's without starting N1MM logger.
BTW, the Manual shows a little Icon for Winkeyer, looks like a morse key, this icon I can not find, even with contest mode enabled.
Maybe a sign for another mistake I made?
vy73
Thomas
DK3DUA
Post by G4POP » 08 Oct 2017, 18:18
No the icon was removed from the main tool bar and set in the 'Radio' drop down instead, much to my dissapointment
kd0zv
Post by kd0zv » 11 Jan 2018, 02:33
G4POP wrote:
08 Oct 2017, 18:18
Radio drop down? Radio menu?
I hope it gets but back on menu. Please....
