Page 2 of 2
Re: Icom 7300 and cat control
Posted: 13 Jun 2019, 14:56
Once set and saved it should be locked, did you check the latest edition of our user guide page 191 》》》》》
Posted: 13 Jun 2019, 15:37
by WB8AM
Indeed. I was able to enable the FLDigi interface, set "send freq to FlDig", set "Read freq/tx from FlDigi" and pointed to the logbook.adi file. Opened the Fldigi IO config and verified that the UDP/IP is checked as well as the XML IP is 127.0.0.1 (the instructions on pg 192 reads 17.0.0.1) and port is set to 7362 and then closed both programs and then restarted, but per pg 193 I opened FLDigi first and then Log4OM.
When I go to the Rig control I'm still not seeing XML-RPC. (I have version 4.1.03 of fldigi).
Thanks!
Brian
Posted: 13 Jun 2019, 17:01
What do you mean when I go to rig control, where and what?
Posted: 13 Jun 2019, 17:33
by WB8AM
Sorry, I meant Rig control under fldigi's configure menu. But, I think I'm seeing some progress... I'm working on the software remotely with my radio turned off. Will have to wait to see once everything is up and running at home.
Incidentally, how did you enable the VFO display in your FLDigi integration video (above the Extended info & QSL button)?
-Brian
Posted: 13 Jun 2019, 17:42
That's the point, Fldigi is not using any rig control that's done by log4om and sent to Fldigi via xml/rpc
You may need to rotate the radio dial or click a log4om cluster spot to wake up the Fldigi display
The freq reflected on the waterfall is set by a check box in Fldigi configuration, otherwise it displays soundcard info
