I have not received your support request yet, did you send it?
Please copy the SQLite database to your desktop and try to open it in Log4OM from the desktop
Also zip the SQLite file and email it to me please
Change database
Re: Change database
Re: Change database
Yes I did. I have resent it with the info you requested. Opening the database from the desktop fixed the issue.
As always, I am very grateful for your help. Please let me know if you need any further information.
Cheers
Guy
Cheers
Guy
Re: Change database
I have now received your support request and the trace log indicates that the path to where your SQLite file is stored on either a network, partition or some form of additional drive.G4DWV - Guy wrote: ↑09 Oct 2017, 12:38 Hi Terry,
Cheers
Guy
This is not normally a problem unless the security for that network/partition/drive had blocked access in some way
Opening your database from the desktop has proven that there is some issue on your computer regarding security or sharing that is stopping Log4OM being able to access the file.
Clearly your issue is a local computer problem and not a Log4OM issue and without being able to interrogate your computer using something like Teamviewer it is not possible for me to define the actual cause.
Your best plan is probably to do as I do and store the Log4OM SQLite files in Dropbox
Re: Change database
Some further info on this. I just tried to log a contact and there was a message in the lower right about the DB needing an upgrade. I then went to open it from the previous problematic location and it opened perfectly without any issue without any changes in security settings or anything else.
Computers eh?
73 de Guy
Computers eh?
73 de Guy
Re: Change database
Hello Guy,
You might check out this thread for a similar issue which several of us have had and the workarounds we have found. viewtopic.php?f=7&t=3028
Let us know if that helps, or if the problem recurs.
Doug - W7DRM
Doug - W7DRM
Re: Change database
Hi Doug,
Once I got the database opened from the desktop, even though that itself did not work, it allowed me to open the database from the original location and since then, <touch wood> all is working FB.
Thanks for the link, I'm just about to have a look.
Mni tnx es 73 de Guy G4DWV 4X1LT
