Hi all,
The solution was much more simple than any of the suggestions. The answer was provided by Alex, the autor of Omnirig.
The thing to do was to not have the COM port selected in the radio drop-down tab, but to have Omnirig Radio 1 selected.
73 de Guy G4DWV 4X1LT
Transmit always on IC-7300
[solved] Transmit always on IC-7300
Re: [solved] Transmit always on IC-7300
What Radio drop down - DigiKeyer or WSJT-X????G4DWV - Guy wrote: ↑21 Oct 2017, 17:19 Hi all,
Re: Transmit always on IC-7300
It was the latter, viz JTDX where Omnirig had to be selected.
Cheers
Guy
Cheers
Guy
See viewtopic.php?f=10&t=3109#p17220 for WSJT-X substitute JTDXG4DWV - Guy wrote: ↑21 Oct 2017, 18:06 Hi Terry,
Cheers
Guy
3rd line down
???G4POP wrote: ↑21 Oct 2017, 18:22
3rd line down
G4DWV - Guy wrote: ↑23 Oct 2017, 10:04???G4POP wrote: ↑21 Oct 2017, 18:22
3rd line down
so for you read 'In JTDX settings/radio select Omnirig'In WSJT-X settings/radio select Omnirig
