import adif log file
IU3CYV
Post by IU3CYV »
after import adif file no qso found..
why?
73 de Tiziano IU3CYV :roll:
(old callsign IW7EFC)
K7PT
Re: import adif log file
Post by K7PT »
Did you open the database from the File drop down?
IU3CYV
Post by IU3CYV »
of course, I make database before and after I imported Adif file.
see below
What Chuck means is:
Have you opened your created database via the Log4OM file menu after you created it.
This should be made at the first step. After that you can close Log4OM and reopen it.
Now Log4OM is connected to your database on each new start.
You can see your database connect status at the lower right corner of the Log4OM Window.
So import is only possible if you are connected to the database before you import ADIF data. ;) ;)
IU3CYV
Post by IU3CYV »
see below
But it is very strange, when I choose adif import an I click import button the progress bar does not move forward...
why?
Looks like your communicator is not online. If Log4OM starts it opens normally
the communicator and start it. Could be possible that you have set it not to
Autostart.
Start the communicator and retry the Import. Think that ADIF Import is impossible
when the communicator not runs and is started.
IU3CYV
Post by IU3CYV »
no yet... I tried but not work.
Have you both "lights" for the communicator green like attached picture.
and have you both symbols in the Windows Taskbar as attached ... 1 = Log4OM main program and 2 = Log4OM Communicator ?
IU3CYV
Post by IU3CYV »
left is yellow right green...
Hello OM (please activate signature and put your name in),
i am not an expert of all functions of the Log4OM communicator so i have send an
eMail to Terry (G4POP) that he takes a look to this thread. Stay tuned ...
