I go into utility cluster I click on DXFUN but nothing happens no spot DX can you give me the installation parameters
THANK YOU
parametrer cluster
Re: parametrer cluster
It works fine for me!
You did DISSCONNECT from the original cluster first then select DXFun from the drop down and lastly click Connect didn't you?
yes I have DXFUN in the window but when I click on CONNECTED a window opens and tells me <NOT CONNECTED> i
My internet connection is very good. Before I used a hard drive and cluster worked but it is HS so I installed a new hard drive and re-installed all my logitiels. Except Log40M cluster that refuses to work I click on the address a box opens and tells me <NOT CONNECTEED>
Everything else works and I pilot my IC 7300 the frequency is displayed well at the top right of the logitiel page.
Can be a problem with <cluster wiev controle.dll> ???
If one can m '(send here this DLL I would install it.
Thank you
Thank you
Yep I recon Chuck is correct one of the following
1. Firewall
2. Anti virus or Malware software blocking
3. Not running Log4OM as an administrator
4. Uninstall and re-install Log4OM from a fresh download just in case the original download was correupted
1. Firewall
