Losing Communicator TCP connection JT Alert
Re: Losing Communicator TCP connection JT Alert
No, its not. As a matter of fact I have killed about every unusable process there is running.
Looking at the log.
What XML document?
2017-11-07 21:55:46.5931 ERROR: *** TCPServer: Error reading from socket 127.0.0.1:51253: [InvalidOperationException] There is an error in XML document (9, 23). ******* [Function: #=qakzBsEX5pWlQ6f66E7zJ$58YYPHyyNoqnrS2BcGiDT4=] System.InvalidOperationException: There is an error in XML document (9, 23). ---> System.Xml.XmlException: '.', hexadecimal value 0x00, is an invalid character. Line 9, position 23.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.ParseNumericCharRefInline(Int32 startPos, Boolean expand, StringBuilder internalSubsetBuilder, Int32& charCount, EntityType& entityType)
at System.Xml.XmlTextReaderImpl.ParseCharRefInline(Int32 startPos, Int32& charCount, EntityType& entityType)
at System.Xml.XmlTextReaderImpl.ParseText(Int32& startPos, Int32& endPos, Int32& outOrChars)
at System.Xml.XmlTextReaderImpl.ParseText()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlReader.ReadElementString()
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderTCPMessage.Read3_TCPMessageItem(Boolean isNullable, Boolean checkType)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderTCPMessage.Read4_TCPMessage(Boolean isNullable, Boolean checkType)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderTCPMessage.Read5_TCPMessage()
--- End of inner exception stack trace ---
at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
at System.Xml.Serialization.XmlSerializer.Deserialize(TextReader textReader)
at LogOM.TCPServer.TCPServer.#=qakzBsEX5pWlQ6f66E7zJ$58YYPHyyNoqnrS2BcGiDT4=(ServerChildTcpSocket #=qtS$SK3bOyXf9RLtE4isBCw==, AsyncResultEventArgs`1 #=qKvAQlslvI0KPSM1ErEvF8w==)
2017-11-07 21:55:46.5991 INFO: TCPServer: Closing TCP Connection [RESETTING CHILD SOCKET]...
2017-11-07 21:55:46.6036 INFO: TCPServer: Closing TCP Connection [RESETTING CHILD SOCKET]...
What XML document?
At the moment... I have it working. WCF is not running but everything is communicating fine without issues.
Once I took a step backwards and stop looking at my new FT8 installation I tried. FLDIGI and found I had the same issue.
So backed up and found that entering a QSO in LOG4OM and deleting it would drop the TCP connection alone
So I uninstalled Log4OM and reinstalled. Had the same issue again but all my user settings were still there. So this time I uninstalled/reinstalled and deleted the user/roaming profile. Set everything back up and it is holding the TCP connection.
I have an issue with my QRZ uploads where its not shading contacts green for LOTW. I don't know if it has anything to do with how LOG4OM is uploading them (or me not doing it right). I have a support request with QRZ now and waiting for an email back.
Appreciate all the help.
See my answer to your other post re QRZ logbook
For what its worth I can get WCF to run but I have to kill everything that is running on 8081/8081
There are several things on my machine. Its a pretty common port. I even have a mouse for my CAD software that uses the port !
But seems to run fine without WCF
