Cluster Mode "Link to Radio Mode"
Using Log4OM with my Flex 6500.
The Flex has DIGU and DIGL for digital modes.
When I change the box to Link to Radio Mode it only shows SSB spots instead of Digital.
Do I have something set wrong or is it not possible to detect the DIG mode from the flex?
NN7D
Re: Cluster Mode "Link to Radio Mode"
Post by NN7D »
Hi Rich,
This issue has been covered extensively in the past. Check out this thread - viewtopic.php?t=2198
So for now, you have the choice to modify your OmniRig's <rig>.ini file to reflect your rig's digital mode when double clicking on a digital spot.
The other suggestions for improving Log4Om's logging of digital modes will hopefully be added to V2 - in progress. They are on the Mantis list.
I hope this helps.
Doug - W7DRM
