LOTW error
w9mdb
LOTW error
Post by w9mdb » 14 Dec 2017, 14:36
LOTW started putting comments in their download files
So when you look at statistics and awards, for example you see this
IL // ILLINOIS *** NOT FOUND ***
So far it's only for CNTY and STATE
<CNTY:15>FL,HILLSBOROUGH // Hillsborough
<STATE:2>TX // Texas
So it appears the ADIF parser is not using the field length to truncate the fields
de Mike W9MDB
w9mdb
Re: LOTW error
Post by w9mdb » 14 Dec 2017, 16:35
If you download the sqlite3 command line utility you can fix this until LOTW or Log4OM fixes this.
Just run 'sqlite3 database.sqlite' with whatever your database name is and do this:
update log set state=SUBSTR(state,1,2);
de Mike W9MDB
