Log4om 1.31.0.0 database issue
VK7XX
Re: Log4om 1.31.0.0 database issue
Post by VK7XX »
VK7XX wrote: 28 Jan 2018, 03:51 not a big issue, but annoying. Since upgrading to the subject version, it now takes a full 4 minutes to load my database (SQLite) whereas, before upgrading it used to take about 55 seconds. Did I miss something with my upgrade ?? is there anything anyone can suggest to speed this loading up ??
regards
John
Well, as it turns out, it IS a big issue. I have discovered that if I make an edit to any call, the changes take (in my case) 4 minutes to save and during this time my digital modes software hangs. The exact same thing is happening with Norm, VK7AC (who is not a member of this forum) Norm has just finished reinstalling 1.30.0.0 and he tells me it is working perfectly. It is obvious that there is a BIG problem with 1.31.0.0 so, in a few moments I too will be going back to that older version.
regards
John
VK7XX
Post by VK7XX »
VK7XX wrote: 28 Jan 2018, 20:09
regards
John
regards
John
Adding info for the interest of other readers... I have just completed re-installing 1.30.0.0 and yipeeeee, everything is back to normal. My database loaded in the usual 35 to 40 seconds and speed of everything is back to normal.
If you too decide to step back one suggestion, when 1.30.0.0. completes a box pops up asking if you want to launch Log4om and Onmirig... I suggest you untick the Log4om box, and allow omnirig to launch on its own this first time. Once the omnirig launch completes (a few seconds) then start log4om..
regards
John
VK7XX
I'm investigating the issue. Expect a fix soon. I'm sorry, beta testing didn't revealed that glitch.
VK7AC
Post by VK7AC »
After updating to Ver1.31.o Log4om has become unusable for me as during my usual JT65 session this morning I usually update my data base downloading from EQSL as well as new QSO,S from jt65 causing Log4om to lock up, I decided to go back to version1.30.0 and again it works flawlessly. I am using SQL lite with in excess of 50.000 QSOs also WIN 10 64bit pro, Tried a 2nd time with the update same thing so I will remain on the older version for now.
Norman VK7AC
VK7AC wrote: 29 Jan 2018, 06:22 After updating to Ver1.31.o Log4om has become unusable for me as during my usual JT65 session this morning I usually update my data base downloading from EQSL as well as new QSO,S from jt65 causing Log4om to lock up, I decided to go back to version1.30.0 and again it works flawlessly. I am using SQL lite with in excess of 50.000 QSOs also WIN 10 64bit pro, Tried a 2nd time with the update same thing so I will remain on the older version for now.
Norman VK7AC
Version 1.31.10 hotfix was released to resolve this some hours ago but the Log4OM website has been down
the webside is on and i have downloaded the aktual 1.31 but the setup file in the ZIP has the date 26.01.2018
so it looks like this is the "non fixed" ... ?
DF5WW wrote: 29 Jan 2018, 11:11 Hi Terry,
The hotfix is V 1.31.10 but Lele is having issues uploading it to the web site and is working on it now
O.k. thank you Terry ... Will check the site from time to time 2day and watching out for V 1.31.10 ;) ;)
It´s on the website now to download ... Downloaded, installed and have tested.
DB loading time is back to normal ....
Thank´s Lele ... :D :D
PA0FVH
Post by PA0FVH »
Version 1.31.1 cured the DB issues, loading and QSO editing.
Thanks for the quick response.
73 Fred
